The simple answer is no you cannot turn a Mantis Q into a G by changing the camera. There is more control circuitry needed to support the two axis gimbal.
So then its possible if I get the cam from the mantis g ? Just need the Schematics and I need to do some rewiring huh? There should be a way to mode these drones like the fpv ones
If you can get Yuneec schematics you will be this forum’s hero!!! The other problem will be the firmware issue since all updates are OTA (online updating).
