Cannot Enter Bind Mode
Hi, My uncle's h plus unfortunately crashed, as i was checking a broken arm and smashed upper plate were immediately noticeable.. i am trying to turned it on but it only shows blinking blue lights, based from the manual it should be re bind to the tx.. but i cant get it to bind mode.. i already turned it upside down as the manual said.. what else i am missing?
Try this.
1. Turn off everything.
2. Turn on the drone and when in flip it over and wait until the lights are yellow.
3. Turn on the ST16 and go in the bind menu and search for the drone while the yellow lights are on.
Hey @Ece31316 did you get it to work? And If you did please share your solution with the community so others with same issue might have a solution [emoji16]
tmsmindspace
