Hi, I took delivery of my H520 and camera's this week so first time poster.
The issue I am having on any camera I connect is that even after calibrating both the gimbal and the controller I cannot get the camera to return to zero.
It starts at zero on bootup but then goes down to 3 or 4. When I check the channels the slider is reporting maybe 6, sometimes higher if I move from one extreme to the other it never actually gets to a zero value.
I assumed that the controller calibration would be setting the travel based on the values it gets when you move the slider from one end to the other and should compensate for a channel not returning to zero but it seems not.
Is this likely why the camera will not return to level and if so does anybody have any idea how to fix this or is this a service call?
Many thanks.
Many thanks.
