- Joined
- Aug 30, 2024
- Messages
- 102
- Reaction score
- 19
- Age
- 58
Do you bind the cam to a ST16? If yes this message is normal and can be ignored. Never try to update CGO3 FW with a CGO3+ FW!During the binding process I get an error message that says the camera firmware is too old.
This is sounding like a mess. The picture is of a CG03, which is also not the correct camera for the Typhoon H. The loose connector just needs to be unplugged and stored away somewhere in case you sell the camera. It has no use on a Typhoon H. The Typhoon H uses the contacts on the mount plate, which does the same thing.? I thought it was a CG03?
But that’s alright it’s working. Well at least the video.
I have a loose connector, where would this go?
The only update I can offer at the moment is that there was also a version V1.9.01(e) for the CGo3. Bad coincidence, but at least we don't have to worry about some Frankenstein firmware issue.I’m running into a little problem....
....Also, does the camera led flash green, or is it supposed to be solid?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
