The small white ceramic component to the right of your scissors which is marked with a "K" is the fuse for power to the camera. Whenever the camera wires get shorted that fuse will blow. It is a 1.5a SMD fuse. It's simply sitting on solder on top of the board.Well Thanks you Rdonson.
Please i need wiring diagram of motherboard. Problem is It in power supply on motherboard.
Lost power on this connector.
Hello I am having a few problems after a crash. My camera was severed at the mounts and the slip ring was damaged. I ordered a new slip ring and installed it. While i was in the gimbel i check all the connections. I have not opened the camera. I have tested the fuse and it is good. I am getting voltage at the mount for the camera, but I get no power lights on the camera, no camera movement, and it will not connect to the controller. Any help will be appreciated.
Which board are you asking about? For the camera or the H?I have found a board online can i change the board and the camera wok or is this a issue i will have to send it to yuneec
Where do you found the information that it is a 1.5a fuse? Because in this thread there are talking about 6a fuse: Brought my CGO3+ back from the dead!The small white ceramic component to the right of your scissors which is marked with a "K" is the fuse for power to the camera. Whenever the camera wires get shorted that fuse will blow. It is a 1.5a SMD fuse. It's simply sitting on solder on top of the board.
When you remove the fuse it is marked on the bottom as 1.5. I have used a 2 amp in a pinch.Where do you found the information that it is a 1.5a fuse? Because in this thread there are talking about 6a fuse: Brought my CGO3+ back from the dead!
