CGO3+ shows rotorarms when making a panorama
Since i while the CGO3+ shows the rotorarms in the upper part of the image when making a panorama.
I don't know if it has to do with it that the unit once crashed, because everything seems to work good
and even the gimbal doesn't show any anomalities.
The camera gives a strait horizon when placed on a flat surface.
Any idea on how to fix this?
WTFDproject
Moderator
Staff member
Premium Pilot
North Carolina Piedmont, USA
It sounds like the top "travel stop" is broken off the front shell. If you look closely with a good light into the gap between the left hub cover and the camera shell, you should be able to see two little plastic travel stops. If there is only one (or none), you will need to replace the front shell.
You mean the shell of the CGO3+ ?
Kozloduy, Bulgaria
Didn't understand the question.
Prepare a stopper from a small bolt instead of the original plastic one.
New Threads
Pavlo
