Change of homepoint
Hi all (again),
Let's say you power up your ST16S and H520 at GPS-coördinate whatever, but, you decide to have it lift off, 50m further. You take your H520, and you put it overthere and there you take-off.
1/ Is the home-point updated when you lift off ?
2/ If not, is there a way to have it updated after you moved your 'vehicle' ?
If 1 and 2 = Negative, a return home (RTL) will succeed in comming back to the place where you originally powered it on, correct ?
Hi all (again),
The home is set when the engines are armed. Once you have enough satellite coverage, you move the drone from one side to the other, by hand, and leave it where you're going to take off from. The RTL leaves it in the place where you take off or in the place where it is when you arm the engines that is when you are going to take off.
Jesster0430
