Tried charging my batts this morning before heading out for some flight time but I'm getting solid red light, which means "error". Checked the fuse and that's not my problem. Any ideas, please?
Pull the battery out and re-insert it.
If that did not work, check the 3 balance pins in the base of the charger, make sure one of them is not stuck in the down position causing it to not make a connection.
