When I use my IPhone the camera tilts (pivots up and down) fine - when I use the controller the upper left 4-way buttons, the forward and back (top and bottom of 4-way switch) should tilt the camera up and down - and it does not - the camera ONLY rotates up - and once in the totally straight position, I can not move the camera down. I'm sure this is operator error but wondering if anyone had similar and found a solution?
If I position the camera straight down in Pilot mode with my Cell Phone.. then switch to the controller mode, here's what happens:
When I push forward (up) on the 4-way switch the camera tilts up
When I push backward (down) on the 4-way switch the camera tilts up (Same as pushing forward)
If I push right or left the Breeze rotates right or left.
Ideas?
Ideas?
