- Joined
- Oct 11, 2017
- Messages
- 66
- Reaction score
- 19
- Age
- 51
Sure you can, at your own risk. Many places that are indoors still get GPS signal, but they can't be trusted for accuracy. So there is a risk if you lose contact with the drone that it thinks it has a position to RTL. It climbs (or tries to climb) to your pre-set RTL altitude and tries to get to whatever position it thinks you took off from. If you lose signal and are in indoor mode, it simply lands where it is.So that, can't I fly with manual mode in indoors?
And to stay on topic pilots on here are confusing manual mode with other manual modes.....manual mode on a yuneec is equivalent to atti mode on other birds...we don’t not have a true manual mode unless you hack the flight controller... being a fpv racer I am used to full manual controls ( but I think I would wreck the aircraft do to its lack of propulsion) in atti mode the only thing that changes is that the a/c does not lock on to a gps point ( it sets take off ,and home point, altitude,even logs you flight data, landing point etc.) the change is the UAV won’t fix on a gps point. So the UAV will “float in the breeze” makes for taking nice smooth video if you use the wind to your advantage. I am not sure what happens if the UAV reaches a geofence or a distance limit if the drone will stop at that point in manual mode...( I’ll give it a test next time I take it up).
That is correct. GPS is still being monitored and can be activated at anytime, but not used while in manual mode unless RTL is triggered or switched to another mode that uses GPS.So, if I understand you ... With manual mode RTL still works, with indoor-mode not ?
After the full update, I still can see the option "Enable Indoor Flight Mode" under settings -> VehicleHas INDOOR mode been removed or am I mixing up my terms. This is directly from the 3/11/2019 H520 manual (color applied for emphasis by me):
MANUAL FLIGHT MODE
Manual Flight mode is selected either by flipping switch S4 to the top position or tapping the flight mode
soft key on the DataPilot™ home screen. Manual Flight mode disables all GPS on the H520, however
altitude is maintained using barometric sensors. Manual Flight mode enables the Pilot to fly in GPS-denied
environments such as indoors or under/around obstacles. Manual Flight mode will not prevent drifting
during maneuvers, hence the Pilot is required to apply opposite stick input to stop drift. Manual flight Mode
is indicated on the H520 by the yellow LEDs on the two rear motor arms.
