Drone Cases
Has anyone else improvised with their case situation? My Typhoon came in the box, so I really wanted to get my investment into something a bit more robust.
I revived an old Pelican 1650, cut the foam accordingly (removed some from the top too, due to clearance issues), and saved the hard foam from the stock box.
Also am storing some of the charging peripherals and memory cards in a smaller clear case Pelican. Everything ended up pretty snug, so I lucked out! I'm interested to see some other ideas that you guys have had out there!
Reactions: paulyoung666
tmsmindspace
