First power on - no GPS, 2nd power on, all OK
Westinster, CO
I find this interesting, when I first power on the Breeze I don't get any GPS - WiFi connects to the phone OK, I get into the Breeze app - but no satellites. I then power off the Breeze and power back on - all is fine. This happens all the time - unsure if it has not happened. Perhaps my power on sequence is wrong?
I turn on the Breeze, set it on the ground. Wait for the beeps - connect the WiFi, go to the Breeze app, link the controller - but no satellites. I turn off the Breeze again, power it back on - repeat the above and all seems to work. I don't recall the other Breeze's I have flown having this minor issue.
Suggestions?
scott
Contact customer service. Mine does it after a full battery flight (100% down to 30%). Swap to new battery and power on I get red light on PowerLED, then when I connect the GPS is red with 0 satellites.
I’ll be sending mine in after I get to Michigan. I don’t want to start the process in Florida then head for Michigan and have things get fouled up in shipping. I talked to Mitch in CS when I called after having the problem on the books for a month.
Good plan. I’ll talk to them tomorrow.
Just went up on Yuneec site - I don't see the CHAT button any longer. Does anyone know if this has been removed ? Was always on the mail page before.. (UPDATE) the web page was being worked on, the Chat is back up now.
Reactions: DoomMeister
UPDATE - waiting 1-2 minutes for first satellite lock (initial power on) can be normal depending on overcast sky's, metal in the area, any interference. While not the case, I'll try waiting longer. As for the 2nd and 3rd, .... power up - capacitors are storing some charge making the subsequence power up and satellite lock times much faster.
trademark analystip
