Flicker on video
Hey friends
Does anyone get flicker in video when at 90 degrees. If I tilt a little down it goes away. Does anyone have a fix. It didn't do that before
That flicker you're seeing is most likely from the sun shining thru the props. It's a common issue and can be corrected by using a slower shutter speed. An ND filter is often used to reduce the amount of light thru the camera lens which allows you to use a slower shutter.
Reactions: danomite24
Steve do you know where to get nd filters I've look and look and I can find no one who is selling them
Steve your a life saver I have months looking and reading threads for NDS this is the first time getting anywhere with this question. I just bought them. Do you mean the ring with glass that comes off the lense???
I'll see if I can find any. They are rather scarce. Did you buy your H Plus used or new?
I would like to think that but quite some time ago there was a thread about this same subject. Do you have it set at 1080 or higher ? Somebody on here will know if they see this thread what else to try.
On 4k 60fps
Bdog
