No. I move the directories with the camera captures off to a drive on the PC.Do you format the card after each flight?
After you copy the files from the card to your computer, it's best to format the card before using it again.No. I move the directories with the camera captures off to a drive on the PC.
For what reason? The file system will not change.You should always format the card in the camera before using it again.
Some people format their cards in their laptop or PC's and this can cause problems. I always format my cards in the Camera that I am going to use them in DSLR's or Drones.For what reason? The file system will not change.
I’ve been having a lot of issues with my cards from all sources( drones cameras audio recorders) after the latest windows update... since then I started using the device to reformat not the computer.Some people format their cards in their laptop or PC's and this can cause problems. I always format my cards in the Camera that I am going to use them in DSLR's or Drones.
Regards.
mike
How do you format card using controller ?I’ve been having a lot of issues with my cards from all sources( drones cameras audio recorders) after the latest windows update... since then I started using the device to reformat not the computer.
No I format in device itself... I.e. In the camera, in the drone, in the audio device etc.I’ve been having a lot of issues with my cards from all sources( drones cameras audio recorders) after the latest windows update... since then I started using the device to reformat not the computer.
If you have the card installed in the camera, the format should be in the camera settings menu.How do you format card using controller ?
