- Joined
- Oct 30, 2016
- Messages
- 1,201
- Reaction score
- 439
- Age
- 47
well this is stumper I need to be able to read the tlogs. I did 8 flights and want to review the flight data. I have q ground control main windows program installed on my laptop.
Try using mission planner. Download for free.well this is stumper I need to be able to read the tlogs. I did 8 flights and want to review the flight data. I have q ground control main windows program installed on my laptop.
I had this problem before with the 520. There's three things to try. One use Qgroundcontrol to download the logs, or retry to download the logs in mission planner. Two, use mission planner to convert the logs files (I don't have a computer in front of me at the moment, but one of the options where you download the logs is convert the log). Three (and you'll want to do this anyway after you get the logs), delete all the logs off the airframe after you've downloaded them. Reason: log files can become massive and can cause the desktop software to respond very slowly while attempting to brief the log files (you will start to see log files with no size indicated or pending). I delete my log files after every two days of flying. Also, upgrading the internal card on the flight control board will cause errors with logging and other items (if not upgraded properly [and I don't have the proper procedure to explain upgrading to a bigger card]).missing params 0 vs 1
is it possible to send my h520 back to yuneec and have them upgrade the card to the largest size possible.
currently 8 full flights 2megs a flight 16 megs it when loading missions and maps that going to eat 8 gigs real quick
