- Joined
- Dec 20, 2020
- Messages
- 19
- Reaction score
- 3
- Age
- 61
Has anyone used these GiFi batteries for Typhoon H520 or H Plus? Just wondering if these are reliable batteries?
There are mixed reviews (experiences) with the GiFi batteries. I can tell you the case on them is not as sturdy as the OEM cases and the latch spring is weaker as well. With some of the failures we’ve heard about on the forum I am led to believe their QA (Quality Assurance) program at GiFi is lacking, but that can be said about a great many things that are imported to the US. There is an issue with finding OEM batteries, but with the opening of a new Yuneec franchise in the USA we may start seeing an inflow of consumables like batteries.Has anyone used these GiFi batteries for Typhoon H520 or H Plus? Just wondering if these are reliable batteries?
The H Plus can use the LiHV batteries for the H+/H520 or the LiPo batteries from the earlier H480 Typhoon H. If you use the LiPo batteries the low battery warnings will not occur at the same battery capacity as with the LiHV packs.
I have 2 of the Gifi 8050 Mah batteries and have had no issues.
As I have mentioned in my previous posts about my GiFi 8050mah battery experience, mine also rattled but was pieces of the plastic contact block disintegrating inside. So it would be prudent to check the outer large deans contacts (+ and -) on the battery before flight looking for separation, or the contact receding backwards.....
