It was the obs but that happens at times but not today. I also have to take care of the right hand joystick from the squeals when revolving it. Cleaning I suspect. I have the name of the stuff you recommended.Do you mean GPS or OBS? I wonder because GPS doesn't make any sound. OBS makes a machine gun sound, but normally it is too low for me to hear unless it's on a recording.
That's weird also but I have 3 st.16's that do the same. the system settings are right. Last dumb question? The lights on the craft are not supposed to be the same color after calibrated are they?It was the obs but that happens at times but not today. I also have to take care of the right hand joystick from the squeals when revolving it. Cleaning I suspect. I have the name of the stuff you recommended.
Thanks again and it all makes sense.The photo above was to have you set the RealSense according to whether you have one installed or not.
The Advanced Mode being on allows you to have access to the automated flight modes like Orbit, POI, and CCC.
There was another post where you mention getting GPS Ready indoors, but stays in Acquiring when outdoors. You may need to take it to the park in an open grassy area and leave it on for 15 minutes to give the GPS time to update.
Got it, now when the sun agrees I will go to the park.Exactly where I am now.
Peter,Got it, now when the sun agrees I will go to the park.
Still hear the noise after applying but I will get back to you later. They had the same lubricant you recommended.
Peter, the Pics show the stick is good in Hardware Monitor. But the included Picture from the Channel Settings screen suggests it might be a good idea to check the "Final Output Display" to ensure the affected channel does not have a bias in it.I just sent you 4 pics.
By far the best DEOXIT 5what is the best lubricant to use on the pots.
