The felt slider for the battery at the bottom of the battery cage has come loose. The insertion of battery jams up this
Piece of felt tape. Once battery is in place the only way to remove battery is with a pry tool.
Can I only remove the top cowling to get at the felt tape and glue it down or must to remove both top and bottom ?
Has anyone found a source for some type of replacement felt tape?
If I completely remove this felt tape at the bottom will the battery jiggle and cause issues ?
