H520 and E90 parts and teardown
Brisbane Australia
For those who like me just want to know.
After all what else am I going to do with them. :p:D
984B52A5-2C7C-4867-9D24-E8A4D1BCDF52.jpeg 40533E49-58E3-4B99-A5A1-A533ACA408CE.jpeg
GPS Compass H520 only
D4791E42-857F-4892-B084-8A8E2E384182.jpeg 2C6BD58B-9336-4547-A9E7-1131F233C8A7.jpeg
Camera slide mount same as H480
84C714E2-16C7-47FC-A2C2-10AB93DA103E.jpeg 23B86F1D-F09F-4403-9240-96E1CB81547C.jpeg
Propeller base same as H480, tricolour led cover H520 only
7E5597A4-A7CB-4ABC-BDA2-432F633EF3E1.jpeg 3995AC25-27D3-40E9-9B37-BA2C5A3D8A28.jpeg
Tri colour LED H520 only
FE576690-609F-4D5A-AD58-52AE1C3B22DC.jpeg 8F43086C-8F5E-4B95-AB75-6D931C4F4438.jpeg
IMU H520 Only
D6BF8C01-267A-4B93-AA54-DAF8E0F158F1.jpeg A589218E-003F-4A0A-9D97-A61B14BEE259.jpeg
Landing gear connectors same as H480
E63D5CD8-421B-4F05-BAC7-FCFAC0C35FF5.jpeg F5EE617C-E381-4663-82CC-73618DCA75E0.jpeg
SR24 receiver same as H480
C1EE8AB2-72DA-4532-86D0-CD468FE826CF.jpeg FBB83722-9A5C-4896-A035-19872A938308.jpeg
Sonar sensor same as H480? It is a V2. Will have to compare it to a H480 Pro one to be sure.
5F709B70-AD74-4A69-BA07-3B333E86FE24.jpeg AA57CA2E-2B1F-425E-B79A-6765584EE5D5.jpeg
Micro USB connector board same as H480
FF0D0625-BD2B-4D0A-9F01-39A45098B39D.jpeg 4F3E2CC8-ECFA-4B08-9FA0-BA779B6EFA2E.jpeg
LED Switch same as H480
E90. H520 only no parts the same as H480
There are a lot of connectors and very fiddly to re connect everything. The last few photos show how to re connect the ribbon cable when putting it back together. Just be patient with the little plugs.:p
67331DC4-A82A-460C-A43C-C25629DB3C5C.jpeg DC110886-0314-45A2-A35A-4FA6CA31AA4D.jpeg E5B5F3AC-A7EA-4790-BB4C-4BC35FDFB71D.jpeg 5BE6E2A6-98F9-4B12-A433-E4D79C8C89F6.jpeg 0A61FF82-34DF-4819-997A-BA527289C81A.jpeg 5F52E8C9-FC2B-4A99-92D5-9C7E4A1784B7.jpeg 6B22962E-ED35-4724-9F3A-AD1BF1DA1FA1.jpeg
4E3A2DAF-7645-420E-BF5D-9008D6F4973F.jpeg 7D9A1F74-2D54-48EF-BCDF-E8A95EDBE00E.jpeg
You can see the filter is applied to the lens assembly... And not attached to the sensor.
I have asked Peau about a NVDI modification for the camera but it would be to hard to replace this filter and then refocus the lens assembly.
7CF8EB98-AF62-4F45-9094-E1877ECBD57D.jpeg 3706586A-B44F-4E8A-A685-953050C0D8EB.jpeg
There is s thread at the inside end of the lens assembly, however it is not attached to anything. Focus is ONLY pre set in factory and then glued in with the white plastic ring.
AFD5D3C6-076B-40A7-938B-7A967D22A2C4.jpeg 4CCD8CF2-DE56-4A43-BDCE-77F9FB0E6BC2.jpeg 94CB8A25-34FB-4582-A093-AEB324DF83AB.jpeg A34655C7-AD6E-481A-8D11-82D75BF05378.jpeg 899777CC-33D0-46DE-9EC4-5F87CA854EDA.jpeg 0C943242-460A-480F-B784-1D0CA1153616.jpeg
B954F74D-87AF-41D2-9FFC-C03E76002FE3.jpeg ECB7718D-449E-4DEC-89AD-59AD3B93768A.jpeg ADB15E91-4DD4-43CF-A86E-3DD91651D0DA.jpeg 16BEC2D1-7325-43BC-AE50-AC159D4C5AB9.jpeg F066C9DC-F96F-474F-BEC7-188D61ADF76C.jpeg 5235C135-CBAE-4277-9103-1E1A9536947B.jpeg
I decided to remove the factory mushroom and play around a bit.
The 4Hawks H480 antenna had a nice little pig tail to use. BTW the new H520 4Hawks does not come with it.
E0A93A5B-F517-4FDB-A18C-AAA851099E35.jpeg 44824DB3-493A-4877-9A50-209E8B159EA9.jpeg 10CB831D-070B-4192-BFC9-BEDB9BE34749.jpeg 12F235BD-4A18-4BF9-99F4-D6DCA382D247.jpeg
Interestingly there are two little retaining screws that are not installed on this cover... Mainly add you can't get to them to undo them. It shows that for the first time they got it right not to install these.
I hate it in cars when you are working on the back of the motor and you have to use 3 wobbly sockets to get to a bolt. Because you know they put that bolt in before the engine is put into the car. So thanks Yuneec for not putting those two little screws in :p
571D00E0-0315-4FF9-9452-E2E42E605863.jpeg AC3A6CA2-9B4A-41BE-8DFC-F40E021DB743.jpeg EEDDBB54-6672-410A-8232-1B32FF3C707B.jpeg
Slip ring and top connector same as H480
F04EA69F-D586-457A-8CD6-D46BA5D84DF0.jpeg 0F279208-B30C-4BA1-8244-B9C974FD1C53.jpeg
Here is the VERY hard to get back together ribbon cable. I pushed the thin screwdriver into the foam and pushed up on both sides at the same time. It worked.
ED36C72F-8607-4513-984B-6F08A4D53C4B.jpeg 7A385274-3614-49D3-994A-D7320AD3EAC6.jpeg DFED58DB-834C-41EA-A816-54FB0C2E1DC5.jpeg C9536C99-1B2A-4798-9F88-3EEC2397B97A.jpeg
For those who use a ND filter at find that it is two heavy and you have to add some weight up back. Removing these and the removing the plastic bracing will Lower the weight out front.
Done
Thank you very much, superb cutting work. Very illustrative and that helps to solve doubts :)
Reactions: Haydn
Lot of work in this post.. very informative. Good work
Thanks mate.
Just trying to help out.
We are all feeling it over the new one. But at least we will be able to tell what the differences are hardware anyway. Once we get one.
The photos give a lot of clues but seeing the work you've done....... Do you find it very difficult to opt for a lens change on the E90?
Lens change very easy.
But there is no way to focus it. It is just stuck in there.
Well, it would be a question of the new lens having the same anchoring system and then having a focusing system. If it's gonna work for this camera, it should.
The question we've all understood why I'm asking it, right? :rolleyes:
Sorry mate I'm a bit slow.
What you meaning?
It was a rhetorical question, but I can explain :)
If the camera comes to us with a faulty lens and a member of Yuneec seems to have said that it is not going to be fixed, we have choice to replace it by our own means. If I understood correctly.
Correct.
My concern with this setup is how to get it to mount to it and allow for focusing.
Atm it is a pre focused lens assembly glued onto of the mounting frame.
The frame is very large and I'm sure a big lens could be out in it.
However Peau said they don't have anything that size.
I also think that the end of the lens is smaller in diameter than the diameter of the sensor.....
Therefore I wonder how much better it might get if we were able to get different larger glass.
Weight may have been the contributing factor.
Yes, but in the end the result is the same. I understand that it is a design or manufacturing flaw and that someone will find the solution. It's easier for us to have a physical solution than having to play in post-production :cool:
trienchieu369
