It is with a heavy heart that I'm selling my H520E. I really wanted to do some things with it, but life has gone in a different direction.
I don't know exactly how many hours it has, but I'm pretty positive it has less than 10 hours.
The internal subframe has been professionally replaced, although I have never had a problem with it.
Three batteries, with charger.
Three sets of propellors.
Controller.
Hard case, Pelican-like (it's just as sturdy as any Pelican).
All software and firmware has been recently updated. All works fine.
It is pretty much like new.
It has no camera, except as described below.
$2600
Now for the extra, if you're interested.
I also have a Flir Vue Pro R 640, 13mm, 30hz thermal camera that I mounted on this drone. I designed and printed a bracket system for it. Nothing on the drone was changed or damaged in any way.
The thermal is using the Tarot gimbal that was designed for it. It has the POWER & HDMI VIDEO MODULE.
There is a control box with a receiver and video transmitter (5ghz).
You do need to use a separate controller to control the camera and gimbal, included, the Radiolink AT10 II, which has worked great. This controller will raise and lower the gimbal angle, start/stop video on the camera, take pictures, change the thermal format on the camera (three choices)
This setup uses a separate battery. I've been using a 3s. It is wired for all of that.
This whole set up is certainly a little heavier, but I've had no trouble controlling or flying the drone.
This entire setup fits in the hard case mentioned above.
An additional $3200.
But I can remove all that and just sell the drone.
I'm near Colorado Springs, CO
Controller.
$2600
