Handheld bracket for C23
Seem could use C23 as a standalone gimbal camera and control will app, then easy to carry and use.
So have you been able to get this setup to work? Others I have talked to thought that the antenna in the back would interfere with the mounting of the camera on the grip. Also see this thread, by @Kev Waite
Foward camera mount C23
I remove the antenna for c23, maybe can change the handheld a little higher.
I would be concerned about damage to the RF board with no antenna connected. I'm not even sure how the antenna is mounted. Is it screwed onto a connector? If so, a flexible antenna could be used instead of the mushroom.
Jesster0430
