makes sense. ThanksAs it's more or less a bullet connector you would be able to re-solder the cup and re-use it. If it was outside of the plastic housing that would be a simple thing to accomplish. The problem is you can't really extract the connector from the plastic housing without destroying the plastic housing. You might find it a lot easier to install a new connector.
