Hi all. St16 Turned into brick?
Hello. I have an ST16 that displays message upon loading up (unfortunately Google services have stopped working) and won't respond to anything else but volume control. I have another which I can take parts from but don't know which part to swap. Anybody have info on this? Thanx
@gardman10,
I was looking at your previous posts and you stated that you purchased a used Typhoon H Plus that took a dip in water (fresh or salt?). If that is the case, an ST-16 will not work with with the aircraft. You need the ST-16S. Definitely different software and firmware, not sure if hardware is interchangeable.
I think OP needs to confirm what model he has?
Deal rebuilding the android files.. step 2 reflash to a later build and then update the present build.
rrichesin
