How does the "H" measure the altitude
Hi, how does the H measure its AGL / ASL altitude? Through air pressure or sonar or...?
The H uses a pressure altimeter as the primary altitude reference. Do not depend on it to be accurate. It’s common for it to be off anywhere from zero to 50’. GPS, when satellite count is sufficient, is a secondary source but has a several meter CEP.
Reactions: rdonson
rubikonsgd
