How To Access & Interpret SD Card Flight Data?
My Q500+ fell out of the sky after the motors died. SD card was in my ST10+ at the time. There are various data folders on the card.
Can anyone here tell me which SD card folders might contain info that led to my crash and what to look for inside the folders?
Thanks in advance for any assistance.
Check this pic. Go to FlightLog, Telemetry, and select the highest numbered file. That will be the last flight. Copy the file to your computer and add .txt to the end of the file name. Then you can upload it here.
Look for the Telemetry folder and you will see a bunch of files that look like Telemetry_1444119401271.csv
The file you are looking for will be on with the date of the flight. If you sort by date, it will be the first file or the last file depending on the order they are sorted. Copy that file to your computer and then do the steps I mention above. After you upload it I will help you understand what you are looking at.
DHYradio
