How To: Maintanence and Care of the ST-16
Eagle's Eye Video
Global Village Idiot
Staff member
Premium Pilot
Albuquerque NM
Maintaining your equipment is key to having all of the systems that enable us to defy gravity, work together... and we develop checklists that help us do that with each flight. One of those items on your checklist should be a simple, but thorough stirring of the sticks, just before powering up the ST-16. If you live in a drier area with more dust, it would be advisable to use some canned air, to give the sticks a quick cleaning.
Monitoring your controller is done through the hardware monitor... one of the menu choices in the ST-16 System Settings. One of the better threads, by our own @gwhuntoon on this can be found here:
Reason for Issues with the ST-16
Here is one YouTube video on cleaning the sticks from the outside:
sometimes it works, but other times you must do some minor disassembly of the controller, to get at the pots directly:
ONLY use a electronic contact cleaner that is safe for plastics:
QD CRC Electronics Cleaner
This set of tools comes highly recommended by our own @Steve Carr:
Neewer Hex Driver Set
The hex sizes needed for opening up the ST-16 are 2.5mm and 1.5mm.
Eagle's Eye Video
Staff member
Premium Pilot
Albuquerque NM
OK, so you've gone though the cleaning of the sticks, you go back into Hardware Monitor, and some controls still either show less than 100% deflection, or less than back to 0% on release. Well, I can help you out... but you can't tell anyone, it's secret revealed by @Peter Venkman:
ST-16 Secret Menu Calibration
Some specifics about the secret menu... do not perform this procedure without having completed the cleaning posted above. It does a recalibration of all controls, under the assumption that there are no physical issues... such as dirt or oxidation. If you skip the cleaning process, the secret menu calibration can potentially make the undesired stick behavior worse.
Before performing the calibration, make sure both tilt and turtle/rabbit wheels are centered (where the ST-16 beeps)(make sure you put both wheels back to center before going to the next step)... you must complete the calibration on all controls... both pages, or you will need to restart over.
Click on the link below to go directly to that ST-16 calibration section
Secret Menu - 11 minutes in
Eagle's Eye Video
Staff member
Premium Pilot
Albuquerque NM
A couple of noteworthy threads, covering the aspects of some advanced ST-16 tweaks... adjusting rate curve settings for both flight behavior and camera movement...
Adjusting Expo Curves
New K2 Gimbal Settings
A caution to new pilots... these changes will affect how the aircraft responds to your stick inputs. Please spend at least 25+ hours using your ST-16 as designed and programmed by Yuneec before attempting these adjustments. If you make changes, and subsequently crash as a result of your changes, that will be considered a "Pilot Error" incident.
Reactions: DoomMeister
Very informative thread, thanks! I do have a question though. Are all ST 16"s compatible with all Typhoon H's? I've considered purchasing a newer ground station as a spare or "jic". The one I'm considering has 3 antennae whereas the one that came with my H has only two. What could I expect to encounter as far as pairing/binding, etc.??
Eagle's Eye Video
Staff member
Premium Pilot
Albuquerque NM
The ST-16 (2 external antennae version) and the ST-16+ (3 external antennae version) are compatible with both the Typhoon H and the Typhoon H Pro aircraft. Note that I specified external antennae, because the base ST-16 has 3 antennae just as the ST-16+. It simply has one of the 3 internally. Binding, firmware are all the same for both.
DoomMeister
Moderator/Tech Junkie
Staff member
Premium Pilot
The Vehicle City
As well as the H920, if your eyesight isn’t what it used to be and need a bigger aircraft to stay VLOS compliant. ;)
Reactions: Docdor
Eagle's Eye Video
Staff member
Premium Pilot
Albuquerque NM
Well, you got that bigger aircraft thing covered, I'd say... ;)
Reactions: Docdor
New Threads
Carmel
