Increasing rudder end points?
Hi folks!
I have been really enjoying my H but the yaw seems a little too slow for me. Has anyone electronically increased the rudder end points in the radio settings (from 100% to 150%) to increase the yaw rate with any success?
Thanks!
Ed
I would recommend trying to increase the speed in post processing... too fast a yaw rate
seems to markedly increase the amount of digital breakup I see in video footage.
Thanks for the reply, but I wasn't really referring to video. I was referring to the actual yaw rate of the H for when I am flying around in angle mode.
Not going to try and talk you out of increasing the yaw rate but bear in mind the H is designed around being a camera platform where smooth and flowing yaw is more desirable than high maneuverability. What you do to increase "sportiness" for one mode will be present in all modes. If that's what you want, give it a go but record what the original set up is before making changes. Worst case is you don't like it and want to go back.
Thanks. I think increasing the end points gives the best of both worlds. It gives you a little more "uummph" when you want it, but I dont think it really effects anything when you are on a CCC mission and you want the smoothness and flowness for videos and pics. No need to remember the settings as you can simply reset back to the original ones.
ThatsOneFriendlyMofo
