Im flying outside. When i try to lift the breeze 1ft or 12in the irs sensor turns blue. I bought it at ebay it has a sticker 2017. the sensor is clean. Ty.
I suspect you have a couple prop vanes reversed. Check that your props are all marked properly A or B and match the motor arm. If you watch when the drone starts to take off, the side you see press down into the ground has one or two prop vanes reversed. The s/w decides too much weight as a result. Look closely at the props (when they're not moving ;-) and see if they are oriented properly for that wing and direction. They alternate in direction as you move around the breeze.
