I don't I've only set it up yesterdayDo you have another pack you can try with the Charger?
Hi there out the box yesterday flown the drone came back saying max height 60 as battery low so brought home plugged charger in red solid light checked fuse no issues put new 7.5 amp in still same not sure what Todo now thankCheck the fuse in the charger first... We see this often.
How low did you get the battery ? Did you get it way out of balance ?
What's your charge/balance tester tell you about the cell conditions ?
If the cells get to far out of balance, you'll get an error warning.We can help but need to know the cell conditions first.
A flashing red and green is normal and the cells are being balanced.
Solid red is not good.
