Thanks , yes you are right with a music track would be a little better, next video ...
I have also been kite surfing for several years and I know the kite's behavior in a critical situation(the kite fall in the sea), the lines of the kites are 22/27 meters long at most, so it is necessary to keep the altitude under control, because with the wind the drone can have slight variations.
But I must say that it was a real satisfaction to see that the Typhoon H Plus can fly safely in those conditions without drain too much battery.
And even the gimbal worked efficiently with an image that was always stable.
