Lag on controller
Hi has anyone out there experienced lag on controller screen even when the q is landed it is a broken picture screen like buffering then all good once still but if there is any movement on controller same problem this has also happened to my flying mate as well but only this last week has it got worse coincidentally used cgo pro mode for first time as well thanks for help
I doubt the pro mode would affect the lag. The video is a fairly weak signal is it's common for it to freeze or lag. Always keep the front of the ST10 pointed at the Q. The antenna is inside the flat area on the front of the ST10 and inside the camera on the Q. The signal seems to be better when the camera is facing way from the ST10 or directly at it. Sideways seems to be the worst. The only thing I have seen that improve the signal reception is to modify the ST10 with an Itelite antenna.
With this problem happening to two of you, I wonder if it's signal interference in the area your flying in.
Try another area and see if the problem improves.
Good luck and happy flying,
Jafo
playtime365
