For the H520, I don't see anything in the manual for the LED status. I know it's the two back motor leds that change.
I lost video connection and got the yellow warning on the ST16S only 150ft away from me. I noticed all leds turned purple I believe and flashing. Either I moved it back towards me or it came back towards me (I don't remember) and it almost instantly regained connection.
I'm sure it had to due with interference as the RSSI for video is at -57. At close range it's -55, although I don't know whats the scale.
I have the 2.4 antennas pointed up towards the sky 45 degrees tilt to the left and right respectively and the mushroom towards the sky.
I was able to duplicate the video lost at approx. 100ft altitude but don't remember the distance. It was LOS and for sure no more than 140ft distance away ANGLE flight mode. First time that has happened at this location. It is a residential area and heavily saturated with wifi signals, but again this is the first time this has happened. I flew the H520 and H480 at this same location and no issue previously Solar flare perhaps? Ideas or thoughts?
Thanks!
Thanks!
