I had a very light crash with a pine tree which caused the H520 to slowly tumble down through a few branches and lightly hit the ground with the landing gear up. No props were damaged, and the aircraft had no apparent damage at all, the camera was undamaged except for 2 of the vibration mounts were pulled out. After fixing the vibration mounts, I tried to restart the aircraft. The gear was still locked in the up position, I pressed the start button on the H520 and it light up, the camera came on, but the ST16s showed the camera image, but no connection to the aircraft. I tried several times with and without the camera, but the ST16s and aircraft wouldn't connect. I haven't yet looked at the telemetry, but that's my next step.
Any suggestions are welcome.....
