micro SD card contact lost....intermittent
My H plus says no sd card inserted. Tried 2 and I know both work. No season left here so lots of time to ponder.
Is there a common brand not working? I have several high speed Samsung MicroSD cards (Evo Plus U3) which I tried last week and the controller just said 'Insert MicroSD Card' :(
Had to buy a new MicroSD, went for Sandisk Extreme Pro and no problems at all. Also have a Toshiba Exceria M302 32Gb which works brilliantly.
The good cards without problems for the H520 are the Sandisk Extreme Pro and the Delkin.
I work on Delkin 64gb and 128 gb and no problem for a year.
Samsum extreme pro 128gb doesn't work for me. The 64gb one seems to work. In the end Sandisk and no more problems.
How did you do that. In the controller or camera. When in my camera doesn't know it's there.
From what I am told, if the camera will not detect the card then you cannot format it with the camera. Also, for some brilliant reason the control station will only read 32gb and down in size. So you cant format it that way either.
I am literally talking with Yuneec today about this exact issue.
csandoval
