New Firmware Update
Likes
#1
Hello,
I use the Yuneec 520 with Pix4D and AgiSoft for mapping purposes and when mapping a small area I like to fly with the Gimbal at 90 degrees and then a second flight at 60 degrees to improve the results. When I updated the software on the drone and the controller I lost the check down menu to adjust the roll and yaw on the gimbal. Did I do something incorrectly?
Likes
117
France
#2
The workaround is to do your job like this.
You start the mission with a waypoint where you set the angle of the camera at 90 °.
From this waypoint, you link the grid of photos where the camera will stay at 90 °,
At the end of this mission, you go back by a waypoint where you put the angle of the camera at 60 °.
and you redo the same grid where the camera will remain fixed at 60 °.
So you will do your job with a first pass at 90 °, then the following at 60 °.
By putting a waypoint where you set the angle before the mission, this angle remains for the mission.
Likes
346
#3
Or use desktop version of data pilot 1.1.9 which has all the settings you require and then upload the saved plan to st16s.
I only have the Mac version of 1.1.9 if that helps
Likes
22
#4
I have just tried to find 1.1.9 version searching on google. I have found this page
https://www.premium-drohne.de/shop/yuneec/kopter/28/typhoon-h520-inkl.-e90-und-rucksack and at the bottom there are download links for DataPilot with win version 1.1.11 and Mac version 1.1.9
I have a Win PC so I have downloaded 1.1.11 version but there is no camera angle in surveys and it pretty much looks like 1.3 version for Windows.
Likes
22
#5
ok, the link says on the page it is 1.1.11 but since downloading is coming directly from yuneec website it is 1.3 version. I will keep looking for 1.1.11 as there must be a camera angle settings because it is in 1.1.9 for MAC and they have seemed to be released close to each other.
Likes
346
#6
Sorry this is in capitals but DO NOT FLY WITH 1.1.11 AIRCRAFT FIRMWARE. It was the first one and extremely dangerous. I cannot stress enough that you must not fly on 1.1.11
Using 1.1.19 desktop though will give you what you are looking for with angles. Save the plan and upload to aircraft using latest firmware.
It works and all is ok.
I doubt you will find it by googling though.
Likes
346
#8
Hi Peggy,
I meant a version of DataPilot Planner for Windows , not firmware,
When you said 1.1.11 I just wanted to express to not fly with it.
Datapilot is 1.1.19
Sorry I can’t help you with the windows version
New Threads
Mwchavo79
