No SD card error on ST16S
I can no longer get the camera to recognize my cards, not even the stock one that came with it
SD Ultra HCI (1) 32 Gb
SD Extreme PLUS A2 128Gb
EMTEC HCI class 10 16 Gb
FORSEE 16Gb (came with drone)
every time i try to take a pic or vid, I get the "No SD Card" error on the ST16S
I put them all in the camera and ran format card on the controller,
the SD Ultra 32G prompted format successful.
the FORSEE 16 prompted format successful.
Any ideas?
Does the display on the ST16 show the card is installed?
Try inserting and removing the card several times. Then change the resolution down to low setting and try to snap a picture.
SD shows N/A
I reset all camera settings
powered off swapped out all the cards cards and powered on, still nothing
I don't have a lot of confidence in the cards you list. The SD Extreme PLUS A2 has been mentioned as not working with the Plus. The A1 does work. The C23 needs a card with a very high write speed. There is a thread in this section that discusses the cards and a list of those known to work.
Reactions: weajr
Thanks I'll try finding the thread ...
Found the graphic file in the thread you mentioned ...
Put a SD Extreme Pro 128Gb A1 card in,
the SD indicator immediately showed 118.4Gb free
picture taken
video recording
All is good here
Man, thanks for the assist
Interesting. Technically the Ultra Plus should not work. The write speeds are too low.
adanidharavi
