No telemetry files
Yesterday I was on a real estate shot and renamed the telemetry files so I could keep track of it flight to log them later when I got home. Well they are no where to be found. Any ideas?
They only save in the original CSV file convention unless moved to another location and renamed. They are sequentially numbered while also including the date. If you know what the last number sequence was before starting the shoot they are probably still there but lack your naming convention.
Reactions: Rayray
Ok well I am missing two flights have know idea where they went. So if I install a sd card in st16 and after each flight I can rename flight and save it to sd card?
trepox
