On of the leds not working.
Hello Guys,
After a minor crash (leaves in the way while RTL), one of my frontlights is out ...
Everything else still perfect, all motors OK, no heating or vibration, just one led.
Any idea ? Probably a misconnection, but where to look ? At the motor, or internally ?
By crashing (lightly) ? Or just simply burnt - nothing todo with the crash ?
If you have an ohm meter, you can check if it's wiring or the LED itself
Found the issue ...
The minor crash caused the motor-chassis with led to impell on the axe. The connections of the led were ripped off ... Luckely the cable is still OK (but little damage is visible).
Motor is fine and I could retract the chassis to its original position !
Drone is fine, but led will be to be ordered as sparepart.
Reactions: arruntus
Found the issue ...
Good job and safe flying.:cool:
Reactions: X-Fly
Jesster0430
