So what to do? Keep my reliable H with CGO3+ ? I need 14mm.Yes and same.
Sure Mrgs1 but the CG03+ is 100% ok for me and my clients and I need 14mm for the assignmets I am working with and I very often have to go to 400ft/120m.At least it will a high quality 23mm lens!
Hi, is there only a 23mm FOV cam available for the H3? What FOV has the H+ ?
From what we've seen it is of a higher quality than the CG03+ which the OP was referring too, materials were not mentioned!I haven’t seen anything describing the lens other that focal length and aperture. Please direct me to the specs that say it a coated glass lens vs a plastic lens.
Leica is a veteran, well respected company but I’m not plunking down this kind of money until I know more about the lens and camera.
Eagles...thanx. Do I understand you right... Will the H3 and H+ give me the same view from i.e 400ft as the CGO3+ ?You are not reading the specifications correctly. The specifications for the new H3 are as follows:
The focal length of the lens is 23mm. The field of view (FOV) is 91°.
The focal length and FOV of the C23 for the H Plus are identical.
They both have a longer focal length lens than the CGO3+, because they both have the larger 1" sensor. However the FOV for the C23, the new camera for the H3 and the CGO3+ are all 91°.
And me. That 14mm lens is so useful.So what to do? Keep my reliable H with CGO3+ ? I need 14mm.
