- Joined
- Jul 15, 2018
- Messages
- 43
- Reaction score
- 9
Hello,
I purchased the yuneec breeze a couple weeks ago, and am not sure if this behavior is normal
first instance: flew the breeze for roughly 10 minutes, staying within the geofence obviously, video recording. Landed it without issue. Swapped the battery, and roughly ten minutes later try to use it again. It gives the normal startup town, then a flatter "beep beep" after roughly 20 seconds. The wireless network never shows up. I power cycle the drone maybe 10 times before giving up, flying my other drone and then come back to the breeze after roughly an hour. It works fine for the second, and then third flight with maybe a 5min wait in between. Weather was roughly 70 degrees and overcast.
Flew it again tonight for about 10 minutes, then wanted to swap the battery. I began walking and maybe 10 minutes after landing try to startup again. It gives the normal startup, and then the flatter beep-beep. No wifi broadcast (and no green led showing that) The unit did feel a bit warm. I tried for the next 20 minutes before giving up. Weather was mid 70s, and overcast. I went and grabbed a quick bite, and an hour later it is broadcasting the wifi again, and I had a flight without issue. I was done for the evening, but threw a second battery in and of course it connects the wifi after about 40 seconds. It felt cooler than it did after the first flight.
My questions are as follows:
1. Is there some type of thermal throttling?
2. Is there a mandatory wait period between flights?
3. Is there a guide for the various start-up noises to help diagnose?
4. Does using the reset button also format the photos/videos from internal memory?
thanks in advance. knowing the above will help me determine if I swap this puppy while within the period.
