pilot mode only
hello again Folks
leavin on a trip on the boat, and wanted to get feel of "orbit" on dry land IN A big field. after setup routine could only get it to fly in pilot mode., no orbit or selfie. could not get past the take off button. switch back to pilot and it lies as normal.
am I missing something?.
thanks in advnce
Do you have the GPS switched off?
Also need a minimum of 10 satellites for auto modes.
Launching from a boat, be sure to position the Breeze and use Land, if the boat drifts and you use RTH it may land in the water.
thank you. GPs was on 16 satellites or so .practicing on land to not splash my breeze.no auto modes work. would being close to a NFZ affect this?
Possible that an NFZ could effect it, but suspect the GPS switch may be off.
If this switch is off, only Pilot and Controller are available, even if you have enough satellites in the GPS Status.
hnk ou
just went and checke in front yard 16 satellites am 1 mile from community airpor
t
If it has a tower and you are that close, the NFZ is most likely the culprit.
Reactions: Fxsales1959
rubikonsgd
