Powering breeze without a battery
Hi! I need to get some data off of the internal storage, but don't have a battery. Can I power it with a regular dc powersupply? If so, what's the pinout and voltages?
The voltage is 11.1 Volts.
Positive is the "Vertical" contact. Ground is "horizontal", matching the other two.
Reactions: Pier2162 and jonte
PS: Does the OEM charger happen to provide 11.1v on some pins? Otherwise I'll go find a customizable powersupply!
A 12VDC supply will work.
@WTFDproject is correct about the OEM charger. It has to see proper voltages on all 4 pins in order to start supplying voltage. Therefore it cannot be used to power the aircraft.
Reactions: Pier2162
Thanks, used a dc 11.1v and worked fine :)
Now that I found my toast batttery I see it says 11.1v, sorry for wasting your time.
Looking into either getting a new battery or a new aircraft, the batteries are very expensive :)
No waste at all. The 11.1V is the nominal voltage (storage charge voltage) of the battery pack. The full charge voltage is 12.6V (4.2V/cell) for the 3 cells in series.
Reactions: Pier2162
Aeria
