I have had several crashes. The first was due to being an idiot and trying to impress someone when I first got my H. The second did not damage a blade or motor, neither did a few tips that had happen to me. After the first crash, I bought the guards from Yuneec and that is why I did not have any damage with the crashes that followed. They are especially good if you tip over. A serious crash?.......not much will help that, but it will help to minimize the damage and cost of repair. I now use them because it shows my customers how I look at safety, and for me their perception it very important.HI Craig from Wasaga Beach Ontario would it be a good idea to install propeller guards on a typhoon H.?
You said it was the guards that brought it down, but you didn't indicate how it was that they brought it down.IMHO prop guards are the cause of more problems than they solve...but that's just my opinion.
Some years ago I bought myself a Phantom 2 Vision (the one with just the single axis gimbal) and since this was my first drone I decided to fit prop guards. I think it was either the second or third flight that it crashed. Entirely my fault but it was the pop guards that brought the aircraft down...if there were no prop guards installed it would not have crashed.
Since then I've only ever used prop guards just once when I was doing my flight evaluation for my PfCO (to impress the examiner) and that was on a Phantom 2 Vision Plus. The flight went well and indeed on landing the aircraft tipped over so the guards saved my props. But that was just a couple of props saved. I'm still of the opinion that prop guards cause more issues than they solve. I have not, and will not install them on my TH.
As I said, ultimately it was entirely my fault:You said it was the guards that brought it down, but you didn't indicate how it was that they brought it down.
I understand what you are saying, but through all of that, it was not the fault of the spoke from the guard that caused the crash, it was neglecting to do a physical and inspection, along with being new. Initially you said it flew into you and then hit the ground. If you did not have the guards on when it hit you, you could have been seriously injured.As I said, ultimately it was entirely my fault:
It was only my second or third outing with the aircraft... I was new and green with drone flying. I hadn't checked my switches properly on the controller and I took off not noticing that it was in manual mode. The aircraft took off and promptly flew directly into me then dropped to the floor. I picked it up and gave it a quick look over but I didn't notice that one of the spokes on one of the prop guards had cracked. Believing the aircraft to have not suffered any damage I took off again and once airborne the aircraft appeared to be flying OK. However, a few minutes into the flight the aircraft plummeted from about 100 feet up and crashed in to some snow just missing a woman walking her dog (I didn't see the woman as she was obscured from my view by some bushes). What had happened is that the cracked spoke had broken properly and fouled the prop causing it to stop thus causing the aircraft to crash. Damage was that the camera had broken free and the wires to the camera had also broken. Also a broken prop and, of course, one of the prop guards. The damage could have been worse but for the snow. Thank god I missed that woman.
If I hadn't had prop guards fitted it would not have crashed. If I had taken the prop guards off the aircraft before that flight it would not have crashed. If I hadn't had the prop guards fitted at the time I made the mistake of lifting off without checking my switches it would have probably have broken a prop or two which would have been easy to replace since I had spares with me and the subsequent flight would probably have gone without a hitch.
I reiterate...Entirely my own stupid STUPID fault but, at the end of the day, it was the prop guards that made it fall from the sky (albeit through my own negligence in not inspecting them for damage properly). If they had not been fitted it would not have took that plummet.
All this was a good few years ago. Far more experienced now and I'm anal about checking my aircraft over for any damage before I take to the air. This experience has made me a better, safer pilot as we all should be. Moral of the story: Do your close pre-flight inspections of the aircraft for damage as well as making sure the switches on the controller are correct. Do not assume there is no damage just because it doesn't look damaged on a cursory glance. That way you don't get any surprises.
And I agree Pat, but they do work for the minor ones as intended as they only run about $18 and are mostly designed for side to side or tip incidents. Yes, a real guard would be above and below the props and cost a lot more, but in an actual crash, there really isn't much that would help with the impact other than a form of encompassing airbag that would deploy at a predetermined angle of tilt.Murray,
With all due, for prop guards to be effective for anything more that a minor bumper stop they need to protect the area both above and below the prop blade. They cannot deflect as all the cheesy designs do now. They need to become a shroud, not a thin, easy to bend, easy to break plastic rod that does nothing more that fleece buyers of their $$.
Good pilots don't use prop guards!
Well, actually, with a cage around it, I feel very comortable to fly indoors ...With the exception of large industrial buildings and auditoriums, for indoor work the H is too large. As most corridors are 48" wide an H without prop guards has only 15" of free space on each side if it is flown perfectly centered in a corridor. In such situations prop guards are a solution to a problem they cannot solve. You need a smaller drone.
Any prop guard that can be deflected, via bumping it, and exposing the prop tips just delays prop damage for an additional second or so. If soft tissue can get between the prop tips and a guard there is no significant protection against human injury. If a multirotor using prop guards does not also employ some type of screen under the propellers to prevent object intrusion we still have a drone where the propellers can make contact with objects when the aircraft is descending. Top of head, upheld hand, tree branch, etc. An outer guard ring is virtually useless in such a situation. The current state of most prop guards provides at best only a false sense of security.
If we need to get so close to an object to photograph it that contact with the propellers becomes a concern we're using the wrong platform. They make macro lenses to fit hand held cameras for that stuff.
