Propeller pitch
Somebody knows the pitch value of the H520 propeller? 10"/...?
I don't recall every seeing any specs for the props. What are you looking to do?
This is an explanation with boat props, but should also translate for any propeller.
I used the calculator from the link I posted above on an OEM prop for the H480. It is a 9 in. prop with a variable pitch by my measurements. At 4in diameter it reads 9 x 4 and at 7in diameter I get 9 x 5.6.
I would suspect the H+/H520 props are also a variable pitch.
csandoval
