First place to check is Hardware Monitor. Check the sticks to see if they return to zero each time the sticks are returned to center. If the right stick does not then it will cause drift. The stick will just need cleaned. It's a 5 minute fix. Also watch the graphs to make certain the sticks are not sluggish or jerky and go to 100% in all 4 directions.Just wondering how to correct a straff drift?.. My bird has recently started to drift left (as opposed to hovering).. Accelerometer?..
Follow this video starting at minute 2:20. It's not in English but it's easy to follow. It may take several times to get it clean but it does work well. After it's clean you may need to re-calibrate.Ok Steve, I checked it all out, and did a calibration (via a youtube tutorial).. My right stick (J4) is sitting at 10-12... So do i need to physically clean and air-hose it?...
