Question for you H Plus Flyers..
The easiest way is to look at the battery area.
ST16 has a slide off door. The battery is under the door and connected by actual wires using an EC2 connector.
ST16S the battery itself IS the door. There are no wires. The battery has contacts built in to connect to the controller.
From the top:
ST16 case splits in front of the antennas all the way across.
ST16S splits differently, and mostly behind the antennas.
ST16S has an extra USB port beside the antennas
Front:
BOTH are labeled ST16 on the front (Thanks, Yuneec.)
From the top:
Front:
Thanks for the info, that's easily checkable.
Also from the front, the ST-16S does not have four screws around the perimeter of each the gimbals as does the ST-16. And of course if you turn them on, the difference is clear. ;)
ST-16
ST-16S
Reactions: WTFDproject
Robertwc
