R
Rayray
Guest
If your ST16 has Channels mixed up, or suffers out of memory problems, you can restore functionality by performing either a soft reset or a full reset. Neither reset will affect your firmware updates. (Resets do not correct potentiometer problems.)
Turn on the ST16, then the TH with props removed for either reset.
Soft Reset:
Select Pad, then OK
Tap the circle with 6 dots
Select Settings, then Apps
Swipe left till you see "All" at the top
Select Flight Mode
Select Clear Data, then OK
Return to Home screen, select English
Go to Model, tap Typhoon H
System, Settings, Camera, Select CGO3-PRO
Bind and complete (refresh as necessary)
Factory Reset:
Select Pad, OK, Tap Circle with 6 dots
Select Settings
Select Backup and Reset. Select Factory Data Reset
Select Reset Tablet, Select Erase Everything
Now the ST16 will reboot...Then be sure English is selected
Go to Model, Select Typhoon H
Settings, Camera Select, CGO3-PRO
Bind, tip TH forward 2-3 times at 45 degree angle
Complete (refresh as needed)
Soft Reset:
Select Pad, then OK
Select Flight Mode
Factory Reset:
Select Settings
