- Joined
- Jul 11, 2020
- Messages
- 106
- Reaction score
- 66
- Age
- 78
Is there a listing for the beep codes on the Typhoon charger ?
I suspect the battery is failing and have ordered replacements.
WHen I charge it indicates charging/balancing cells with a RED then Green LED followed by
a beep at 5 sec intervals.
The log does show voltage fell below 14.4 when the Red Warning came up on screen and at which time I could not shut motors off when on ground the drone fell on side flipped and broke one prop.
Not sure if I want to put air until I get fresh battery
