I don't use IOS devices but so long as you can download the app - it should work. But where would you mount the pad? You would probably be better served with an iphone. There isn't much benefit to a bigger screen with the handheld.For the handheld mechanism for the 920 plus can you use an I pad with wifi only? Information will be greatly appreciated
Pat,Amazon has been running quite a sale on SanDisk cards. I normally use 64g cards and those have been running ~$20.00 of late there. Without looking at one to confirm, U3, SanDisk Extreme Pro.
Ok. It said that in the brochure that came with mine however it came with a micro card in an adapter in that slot. There is another covered slot that says TF.card on my cgo4. I read elsewhere that a micro sd card will fit and work in a TF slot. I haven't opened the cgo4 that came with the second 920+ but will do that today and compare. It would be interesting if there is a difference in it. Thanks. I will get back to you.I’ve only seen one card slot on mine. If you have two, use the one on the end that accepts a standard SD card. Do not use a micro SD card and adaptor.
It definitely says TF card on the rubber cover. The V18 has a similar slot and label. Thanks. Guess it's still somewhat of a mystery.I saw that slot on my CG04 and assumed it was for firmware updates etc. It would be nice if it were a redundancy, but if so I would think that it would be advertised as such. I just with the sd card slot wasn't such a pita to get to.
