solution for the GPS Acquiring-Ready issue in south hemisphere
Likes
#21
Hi,
I have made updated my dron and controller with the firmware availble at Yuneec website, but I keep having the same issue. Could you please send me the firmware? I am in an urgent need as I have an expedition soon
Thank you!!
fviddi@gmail.com
Likes
Oshawa, Ontario, Canada
#22
FORUM ADMINS, PLEASE DO NOT DELETE THIS POST !!!AGAIN!!!
I´ve made a FW Update that resolves my problem: GPS allways in "acquiring"; never "ready"
Anybody that wants to test in your TH, leave your email and i will sent to you the files.
This Files are TRUSTED AND ORIGINALS FROM YUNEEC TEAM.
NOW MY TH CAN LOCK GPS: "READY" IN GREEN
my zone: Buenos Aires, Argentina
after FW update the screen shows this
(credit to Leandro from prohobby)
Cheers!!!!
Hello tinchob, I know this is an old post but I am having a similar "GPS acquiring" issue for my Typhoon H that I purchased recently in Ontario, Canada. I brought my H to Trinidad, West Indies and have not been able to achieve a "ready" mode. I performed all the required binding and calibration functions(several times) but still the GPS indicated "acquiring".
I can turn GPS "off" but then being a novice, I did not think it wise to try and fly the H without GPS at a ready state.
Can you send me the files please? My email is varon@rogers.com
Thank you very much..
Likes
I am residing in Indonesia (Java Island) and I am experiencing the same issue with GPS wouldn't lock on my Typhoon H Intel Realsense. Yuneec admins, Please help with this issue. I am running the latest firmware update (Version 3). hendra.sipco@gmail.com
Likes
11
#25
I finally sent my H into Yuneec to get it repaired since it would never work. its been 5 weeks now and I am still waiting. It's getting frustrating since I bought it for Christmas and the only thing I had been able to do is calibrate it and look at the live view from the camera (not much to see at ground level).
I was told about a patch where you remove parts and insulate them better but with the unit being brand new I was not about to just try something out while under warranty.
Hopefully I will get it back soon.
Likes
#26
Cheers!!!!
hola
soy de chile tengo el mismo problema con el gps acquiring mi correo es diego.lopez@chilevision.cl muchas gracias por la ayuda
Likes
#27
Seems I'm late to the party. Currently we are on trip to Africa and I'm from Poland, and we are having same GPS problem. Is it possible to get files? Can you send me files to my email: frydjak2@gmail.com
Thanks for help
Likes
#30
Cheers!!!!
Hi...please send me the updates. Email lemuelnalifuma@gmail.com
Likes
#31
Cheers!!!!
Hi Tinchob,
I'm having the same problem with the GPS signal in my Typhoon H here in Brazil, state of São Paulo.
I've already sent an email to Yuneec Support and they said to update the firmware and try to fly in different locations. However, this advise didn't work to me and I started to fly without GPS.
Could you please send me an email with this files? My email is adilsondisso@gmail.com
The last version available in the Yuneec webpage for the autopilot is v1.35 and v03.01.b30 for the ST16 controller. But, I saw in your picture that your files are related with an earlier version. Do you only update the firmware to solve this problem or you change something in these files?
Thank you very much!
Adilson.
Likes
#32
Hola Tincho. Como estas? Tambien soy de Argetina y con el mismo problema. El TH funcionaba perfecto hasta hace unas semanas que arranco con este problema y probe de todo. Si podes enviame los soft. Un abrazo y saludos a todos. Disculpen que escriba en español. Mi mail: juanjosedossantos@gmail.com
Likes
#34
Hello.
I have two Typhoons RS.
I had instaled the last firmware (European version) in the two ST16 and in the two Typhoon.
Now one works fine, and the other don't adquire gps.
I'm in Canary Islands.
Please, any can send me the firmware to tray.?
Thanks.
irr0286@gmail.com
Likes
#37
[QUOTE = "Jorge Enríquez, post: 156681, miembro: 18102"] Mi correo jorge1ae@hotmail.com [/ QUOTE]
[QUOTE = "Daniel Ribeiro, post: 43755, miembro: 4504"] ¡Hola desde Brasil!
Estoy experimentando el mismo problema que tú.
¿Puedes por favor enviarme esas actualizaciones de firmware?
Aquí está mi correo electrónico: daniel@dtseguranca.com.br
¡Salud! [/ CITA]
[QUOTE = "tinchob, post: 43447, miembro: 3216"] ADMINISTRACIONES EN EL FORO, POR FAVOR, NO BORREN ESTE POST !!! OTRA VEZ!
He realizado una actualización de FW que resuelve mi problema: GPS siempre en "adquisición"; nunca "listo"
Cualquiera que quiera probar en su TH, deje su correo electrónico y le enviaré los archivos.
Estos archivos son DE CONFIANZA Y ORIGINALES DEL EQUIPO DE YUNEEC.
AHORA MI PUEDE BLOQUEAR EL GPS: "LISTO" EN VERDE
Mi zona: Buenos Aires, Argentina.
después de actualizar FW la pantalla muestra esto
(crédito a Leandro de prohobby)
Saludos !!!! [/ CITA]
Me ocurre lo mismo, podes facilitarme enlace?
Likes
#38
I had the same GPS problem. And try to reinstall the firmware with the Windows GUI SW. It stops, and now it doesn't turn on, only the light on the button stays on.
Can you send me that firmware? Thanks
piston73@gmail.com
Likes
#40
This file is only 487KB. Is this size correct?
I tried to load the "TyphoonH_Ver3.04_E.bin" fw of 41 MB from the official Yuneec website and shortly after I started writing, I got the error "Program FAILED!", And now the Typhoon H does not turn on, only turns on the button on / off.
Can anyone tell how the fw is loaded with windows GUI?
Este archivo solo es de 487KB ¿Es correcto este tamaño?
Yo intente cargar el fw "TyphoonH_Ver3.04_E.bin" de 41 MB de la pagina oficial de Yuneec y al poco de enpezar a escribir me salio el error "Program FAILED!", y ahora el Typhoon H no enciende, solo se enciende el boton on/off.
¿Alguien puede decir cómo se carga el fw con windows GUI?
New Threads
donmcnabb2
